fabridelo Friend
fabridelo
- May 2014
September 24, 2015 at 4:46 pm #692312Hello
I have masshead problem when step with my mouse on masshead this change in blue
I tried different things but i no solve.
who can help me?Thank you
TomC ModeratorTomC
- October 2014
- 3155 times in 2495 posts
September 24, 2015 at 4:59 pm #692375Can you check the login info you provided – it does not seem to be working. :((
TomC ModeratorTomC
- October 2014
September 24, 2015 at 4:59 pm #749634Can you check the login info you provided – it does not seem to be working. :((
TomC ModeratorTomC
- October 2014
September 24, 2015 at 6:06 pm #692378<em>@fabridelo 493995 wrote:</em><blockquote>Hello
who can help me?Thank you</blockquote>
Okay, thank you for the PM with corrected login info.
I am not quite understanding your issue, however . . . can you provide a screenshot or two to demonstrate what you are referring to?
TomC ModeratorTomC
- October 2014
September 24, 2015 at 6:06 pm #749637<em>@fabridelo 493995 wrote:</em><blockquote>Hello
fabridelo Friendfabridelo
- May 2014
September 24, 2015 at 6:27 pm #692380Hello
hese photos of the problem
thank you
- May 2014
September 24, 2015 at 6:27 pm #749639Hello
thank you
TomC ModeratorTomC
- October 2014
September 24, 2015 at 6:30 pm #692382So you want the blue background (in the second pic) to be a different color, correct?
TomC ModeratorTomC
- October 2014
September 24, 2015 at 6:30 pm #749641So you want the blue background (in the second pic) to be a different color, correct?
- May 2014
September 24, 2015 at 6:34 pm #692383no I want that remains the same no change no color
- May 2014
September 24, 2015 at 6:34 pm #749642no I want that remains the same no change no color
Saguaros ModeratorSaguaros
September 25, 2015 at 3:56 am #692409PM me the login info and send screenshot the modification you expect, I will check for you.
September 25, 2015 at 3:56 am #749668PM me the login info and send screenshot the modification you expect, I will check for you.
- May 2014
September 25, 2015 at 10:37 am #692469Hello
When I go with the mouse on masshead this remains blue.
I did not understand if it has to work really well.
in this case is possible change color from blue to gray?thank you
- May 2014
September 25, 2015 at 10:37 am #749706Hello
This topic contains 17 replies, has 3 voices, and was last updated by Saguaros 9 years ago.
