  • Pankaj Sharma Moderator
    #879706
    Find the solution given by Ninja Lead in This thread to show the Description in the masthead in this template .
    Hope it helps .
    Josh Friend
    #880094
    Hope it helps .
    Thank you very much for your reply..
    but in default.php, the code already wrote same like solution given by Ninja Lead..
    maybe my case is different..
    it work on this link : http://www.jtbpartners.com.my/v2/index.php/services
    BUT not work on this link : http://www.jtbpartners.com.my/v2/index.php/abd-aziz
    #880323
    I Edited the file "/html/mod_jamasshead/default.php" in template "ja_medicare".
    And added below code after line 22
    <div class="jamasshead-description"><?php echo $masshead['description']; ?></div>
    Now its showing in single articles .
    Kindly add the masthead title and description via Masthead Module .
    Josh Friend
    #880630
    You are really very very helpful..
    my problem SOLVED…
    thank you very much Pankaj Sharma..
    #880706
    You are welcome 🙂
This topic contains 5 replies, has 2 voices, and was last updated by  Pankaj Sharma 8 years, 9 months ago.
The topic ‘Masshead Problem – No Idea How To Make It Work’ is closed to new replies.
