debaleena_das Friend
debaleena_das
- February 2017
March 29, 2017 at 9:29 pm #1023049Hi, Snapshots of the demo attached. Seeing the same issues with my site.
Thanks for the help!
March 30, 2017 at 11:14 am #1023234Hi,
Unfortunately, Edge and IE do not support blend mode. Please see details from Microsoft here: https://developer.microsoft.com/en-us/microsoft-edge/platform/status/backgroundblendmode/
debaleena_das Frienddebaleena_das
- February 2017
April 24, 2017 at 2:09 am #1028341Without an alternative solution, the Template Ja Mono can not be used with out the blend mode function.
I have colored the Masthead Images. For the hover, I have made CSS rules, specifically only for Edge and IE 11 to 14.
La Mono looks excelent in every browser after much work.
Of course it would have been nice if joomlart had provided a solution. And not the buyer must strive for a solution.
Rene
Saguaros ModeratorSaguaros
April 24, 2017 at 7:03 am #1028416It’s always a pain when working with IE/Edge in web development as so many great things MS doesn’t support while other browsers do. Hope that they can support in near future.
Btw, it would be great if you can share your findings here, it’ll be helpful for others.
Thank you, Rene!
April 26, 2017 at 2:34 am #1028878Thanks for your words "saguaros" you say it, I can not understand why Microsoft can not work with W3C rules. For many, many years, IE is the browser to spend the most time when working in webpublishing.
For LA_Mono, I have tested with overlay png images in transparent mode. It never looked good. In the end, I’ve colored all the red photos with Photoshop (Hue / Saturation / Coloring).
And I’ve made CSS rules in the custom.css. For the Edge and IE browser, I make hover rules for black-white pictures without blend mode. For browsers that support Blend mode, I use the blend-mode rules.
Of course you can take from my custom.css file for own ideas what you need.
I have worked on the template La_Mono very long, until it became as it is now.
But La_Mono is a brilliant template, a hugely good idea, wonderfully implemented by your team, it has been worth it to adjust. And let’s be honest, you can rarely take a template 1 to 1 and everything is fine.
Many Thanks
Rene1 user says Thank You to Rene for this useful post
Viewing 7 posts - 1 through 7 (of 7 total)This topic contains 6 replies, has 3 voices, and was last updated by Saguaros 7 years, 7 months ago.
