  • jimboston2010 Friend
    #153816
    First off, thanks for the wicked templates, I really like them and their features. Keep up the good work!
    So here is the situation, I had JA Rasite setup with mega menu and a login module working perfectly. Then I saw Anion and liked it better. I installed Anion, and the login module no longer displays. If I switch back to Rasite all is fine, but I cannot get the spearator->module or module position to work under Anion. Is there something I need to do because I had another JA template installed first already?
    Thanks,
    Jim
    goldorakiller Friend
    #353680
    <em>@jimboston2010 191620 wrote:</em><blockquote>First off, thanks for the wicked templates, I really like them and their features. Keep up the good work!
    Thanks,
    Jim</blockquote>
    I have same problem !
    #353681
    Also noticed profile override does not work either.
    <em>@jimboston2010 191624 wrote:</em><blockquote>Also noticed profile override does not work either.</blockquote>
    i think that the problem is here from the cache function, when you made anything with layouts or profiles, you should turn on the “Development” Mode, and disable the cache fucntion via the template’s configuration.
    With above issue, Please enable the development mode and disable the cache and clear the cache from joomla backend.
    Let me know if it still a problem for you.
    #353749
    Thanks,
    Jim
    </blockquote>
    And for this ?
    I have same issue ! It’s work for ja rasite but not for ja anion
    Very strange
    <em>@goldorakiller 191705 wrote:</em><blockquote>And for this ?
    Very strange</blockquote>
    i catched this issue :), The Rasite template is using the T3 framework version 1.0 which allows rendering extra parameters of the menu via the JA Menu Parameter plguin. But In the T3 Framework version 2, the plugin is combined in the T3 framework plugin and the rendering extra parameters feature is improved better more and some configurations are changed, so that when the site uses the new framework, please re-configure some menu’s extra parameters having the loaded modules function, specially the module/position assigned to the menu item.
    PS: Issue upgrading framework version 1 to version 2: you have to disable the ” JA Menu Parameters
    plugin and install, enable the JA T3 Framework Plugin.
    #353829
    You are right !
    I have disable JA Menu Parameters and re-configure menu
This topic contains 7 replies, has 3 voices, and was last updated by  goldorakiller 14 years, 4 months ago.
