Mohamed H. Jurriah Friend
Mohamed H. Jurriah
November 22, 2013 at 4:20 am #192462Hello
A right module menu is shown when I go into the the page “Støt os”–> “Modtager du giro-kort?”
here is the problem:
direct url: http://denislamiskepulje.dk/index.php/stot-os/2013-09-12-04-42-05/2013-09-12-04-42-6
phong nam Friendphong nam
- May 2015
- 974 times in 888 posts
November 23, 2013 at 9:29 am #513252Hi jurridk,
You can check the Parameters (JA Extended) tab of Støt os and Modtager du giro-kort menu item backend and make sure that you don’t load any module at mega position of these menu item dropdown.
Another solution is hiding the mega position on dropdrown by adding below css styles override into the end of templates/ja_mendozite/css/template.css file:
.mega .group #Mod163 {
display: none;
Remember to clear JAT3 cache after saving changes.
AuthorPostsViewing 2 posts - 1 through 2 (of 2 total)This topic contains 2 replies, has 2 voices, and was last updated by phong nam 10 years, 12 months ago.
