  • mountainman Friend
    #174601
    I have a menu I use in J1.7 which is not working in J2.5
    I have moved from JA Lime to JA Elastica
    The problem is that the child menu does not show on rollover. I have tried a variety of experiments which were of no help.
    However, looking at the source code of the two pages shows that after the menu there is a javascript included on the page which in the JA Lime page has slide 1 while in the Elastica page has slide 0.
    I cannot see where these scripts are built but, I guess, that 1 means that the menu slides when the rollover action occurs.
    Please can someone advise how to correct this?
    Thank you
    Tony D
    This is the script from Lime, the Elastica version has slide set to 0
    var megamenu = new jaMegaMenuMoo (‘ja-megamenu’, {
    ‘bgopacity’: 0,
    ‘delayHide’: 300,
    ‘slide’: 1,
    ‘fading’: 0,
    ‘direction’:’down’,
    ‘action’:’mouseover’,
    ‘tips’: false,
    ‘duration’: 300,
    ‘hidestyle’: ‘fastwhenshow’
    </script>
    Blaine Friend
    #442124
    Ja Lime and JA Elastica are very different templates as are J! 1.7 and J! 2.5 very different Joomlas.
    I would recommend you check the guide for Elastica and see if possibly changing aome settings in the template menu may resolve the issues.
    I wold also suggest setting up th full installation QS of Elastica on local host and seeing the differences we have already configured in that set up.
    Thanks!
    Blaine Friend
    #446747
    May we mark this solved?
This topic contains 3 replies, has 2 voices, and was last updated by  Blaine 12 years, 9 months ago.
