  • metastorm Friend
    #182859
    After turning on in Template Global Settings “CSS and JS Optimize” (Join& Minify), Megamenu, Accordion and Tabs modules does not work. Seems I need some help, please. 🙂
    Ninja Lead Moderator
    #475330
    I used username/password login to front-end but after logging in it redirects to local url, please check it again.
    metastorm Friend
    #475357
    Yes, there was some access problem, fixed. Please try again.
    #475363
    I found the js conflict problem when you turn on the compress js option in JA Nex Template.
    The mootools on your site was conflicted with jQuery com_gcalendar component(3rd party component). I have added jQuery.noConflict(); on this file: components/com_gcalendar/libraries/jquery/jquery.min.js, and it seems like the problem has gone away.
    Please do double check on the problem again and get me in sync with the result.
    metastorm Friend
    #475365
    Hi Ninja Lead,
    The problem is fixed, thank you much! 🙂
    As I understand, I should add code jQuery.noConflict(); in jquery.min.js on every upgrade of gcalendar component?
    #475405
    Exactly or you can make a new js file (with this following content: jQuery.noConflict();) and add this file below jquery.min.js link. Both options are going to solve the conflict between mootools and jquery.
This topic contains 6 replies, has 2 voices, and was last updated by  Ninja Lead 12 years ago.
