  • woluweb Friend
    #202637
    I have recently discovered a display problem of the Megamenu with some types of animations.
    The problem occurs on two sites I have under JA Purity III, but I guess it is more general and that it is a T3 problem.
    So here is the explanation :
    IF
    * using Safari
    with latest Windows version : Safari 5.1.7 (under Win8 btw)
    or with Mac version : Safari 5.1.10 under Mac OS X 10.6.8
    * activating Megamenu animation with Slide and Fade animation
    THEN
    all submenus “fade out” before you can click on them !
    (nb : the Zoom animation does not show normally neither, some collateral problem of zoom)
    My temporary workaround has been :
    * disable animation
    * keep animation but then can only choose Elastic
    Can you please have a look at this problem ?
    (and solve it 🙂
    Txs a lot,
    Marc
    PS : by the way, just as extra information, I have tried to turn on “Legacy Compatible” option in Template Manager, but it does NOT solve the problem…
    http://www.t3-framework.org/documentation/bs3-configuration#global-setting
    Ninja Lead Moderator
    #555195
    Hi Marc,
    Would you like to give me the screenshot with describe on that and URL of your site? I shall help you to check this bug.
This topic contains 2 replies, has 2 voices, and was last updated by  Ninja Lead 10 years, 1 month ago.
