  • pjotrij Friend
    #203268
    I have an issue with my megamenu. I have a menu item under main level which is only for registered users. I have set up the megamenu to group and split like my other menuitems. However, it will not show correctly as megamenu but just as a normal menu with dropdown (dropout) submenuitems.
    The menu it concerns is call Intern and is only shown for registerd users.
    Could you send me some screenshots highlighting the menu item you’re referring to? and how you want it should be as I’m not familiar with language on your site.
    pjotrij Friend
    #557902
    I recreated the submenu, rebuilding every option. And it worked….But after I change the persion for all the items to registered it was incorrect again. Strange….
    Anyone have an idea weher to look to?
    Did you try to take a backup of your site and upgrade T3 framework to the latest version 2.4.1 ?
    Then if problem still persists, pls tell me the menu item you’re referring to, I will check it for you.
This topic contains 4 replies, has 2 voices, and was last updated by  Saguaros 10 years ago.
