  • norito Friend
    #171135
    I did the same setting as the quick-installation demo site.
    I can not make twitter icon shown in mega position. I can set it in Magazine menu but not mega position.
    Hi Norito
    Have you cleaned your Jat3 cache ?
    or update this thread with your login credentials so moderators can take a look at your backend configurations
    norito Friend
    #426668
    Yes. I disabled JA cache in template, but it does not show twitter icon.
    I am using J1.7 template. It seems J1.7 teline template has some problems.
    JA-Tab1 is not shown even I set it up as the quick installation demo.
    Breadcrum is not shown at the top.
    <blockquote>update this thread with your login credentials so moderators can take a look at your backend configurations</blockquote>
    I can assure you that Ja_Teline_IV works fine in many many sites over the world
    Please let us take a look
    norito Friend
    #426674
    I updated my profile and input the site url.
    I’m sorry norito i can’t see anything here
    Could you send me a Private Message with the info ?
    Thanks for your Private
    In mega position can be positioned modules so i can put the twitter module in that position
    <blockquote>I can not make twitter icon shown in mega position</blockquote>
    What you mean with icon ?
    norito Friend
    #426700
    Please see the attached. I would like to do the same. I set mega position but it does not work.
    Also, please check this.
    The breadcrum should not be thereat the frontpage. If you search something, the search result is shown at the bottom.
    1. twitter-icon
    2. breadcrum-position
    norito Friend
    #426701
    Also, please see the tab-setting. I think the setting is right but it does not show at the frontpage.
    1. tab-issue
    Hi norito
    To install your template have you utilized the quickstart package ?
    norito Friend
    #426706
    Yes. I did. I tried and copied the setting but I could not work it out. I do not know why. The breadcrum is positioned and acting very strange.
    Other top menu except Home, it works OK. Only Home menu is showing the very strange breadcrum position.
    The breadcrumbs it’s in your content-main but your Home has type Featured-Articles but you haven’t featured articles published so your content-main is empty and the breadcrumbs appear in that way
    norito Friend
    #426712
    Please look at this preview and next preview.
    http://soccer.kyaku.info/index.php?tp=1&template=ja_teline_iv
    There iare the content-main and breadcrumbs.
    http://joomla.goyat.org/index.php?tp=1&template=ja_teline_iv
    There are no content-main and breadcrumbs in the quickinstall demo.
    You have some problems on your site
    please install again using the quickstart package with sample data installed
    So you can solve in one time all your issues
    norito Friend
    #426841
    This is solved with your Content Main solution.
    Thank you.
    <em>@norito 285309 wrote:</em><blockquote>
    </blockquote>
This topic contains 15 replies, has 2 voices, and was last updated by  norito 13 years, 1 month ago.
