  • adam_z Friend
    #188481
    I have the issue, the sub- menus just stopped working(they are NOT DISPLAYED, i have the error at the line
    [PHP]this.childopen=[];this.imgloaded=false;this.loaded=false;this.prepare();},prepare:function(){var imgElms=this.menu.getElements(‘img’);if(imgElms.length&&!this.imgloaded){var imgSrcs=[];imgElms.each(function(image){imgSrcs.push(image.src)});new Asset.images(imgSrcs,{onComplete:function(){this.start();}.bind(this)});this.imgloaded=true;this.start.delay(3000,this);}else{this.start();}},start:function(){if(this.loaded){return;}[/PHP]
    the error is uncaught TypeError: Object has no method ‘getElements’
    But i Didn’t do anything, the sub menus just dissapeared!! please help URGENT, i need to finish this job in 2 days!!
    PLEEEASE 😮
    Using joomla 2.5.11
    Ja purity 2 template.
    adam_z Friend
    #496967
    It’s really sad that i can’t get help in here, just if someone will have the same problem:
    Solution: find the f*** plugin that did it , in my case it was some flash pic gallery that just neutralized my menus, deleted it now everything works like a charm
    phong nam Friend
    #496991
    Hi adam,
    <blockquote>But i Didn’t do anything, the sub menus just dissapeared!! please help URGENT, i need to finish this job in 2 days!!</blockquote>
    <blockquote>It’s really sad that i can’t get help in here, just if someone will have the same problem:</blockquote>
    We are quitely sorry for our late response because of different timezone. I saw that your issue was solved by disabling your installed 3rd Flash gallery plugin. Do you need our help anymore ?
This topic contains 3 replies, has 2 voices, and was last updated by  phong nam 11 years, 6 months ago.
