  • digitiimi Friend
    #1095515
    Hi, our client noticed a little bit odd and hard to explain problem and they dont want to use the off-canvas menu on tablets. When there is a megamenu available for touch screen devices it seems that the dropdown works only occasionally. If i have undrerstood menu logic right, the first click should open the submenu and the second click open the link. Now it seems that the submenu doesn’t open on every click. The same problem seems to be also on joomlart.com mainmenu.
    You’re right, on joomlart.com, when viewing on tablets/mobile, it will show menu on Off-canvas > click menu item, it will link to destination page.
This topic contains 1 reply, has 2 voices, and was last updated by  Saguaros 6 years, 9 months ago.
