  • hdsports Friend
    #974793
    Hey,
    after updating purity III 1.1.6 to 1.1.7 i have following problem on my site http://www.HDsports.at
    On my megamnu i have submenus.
    When i click on the arrow, than the submenu will open (acutally i have activated also the hover-effect) and i can click on a submenu-point.
    But after update to 1.1.7 when i click on the arrow the submenu opens AND the site load the main menu link, so i had no time to click on a sub menu point.
    Where can i change that? I only want that the submenu opens, when i click on the arrow….
    Best regards, tom
    Pankaj Sharma Moderator
    #974805
    On hover affect the submenu open when you mouse over the parent menu item , its normal, you can check it with demo site .
    hdsports Friend
    #974933
    But it doesnt matter if a activate the hofer effect or not.
    When i dont use the hover effect, the link to the main menu link also opens when i click on the arrow.
    Before update, when i clicked on the arrow, the submenu opens and the page dont load the link to the main menu…
    #974953
    Can u give me some more details , as u said after click on the parent menu drop down is not closing .
    Are you getting same issue on demo site here > purity-iii.demo.joomlart.com
    hdsports Friend
    #974964
    Before update, i had deactived the hover effect. And when i click in the megamnu on a menu-button, which have submenus, than the submenus opens. Now when i click on the menu-button the site loads this link and i cant click an a submenu link
    On the demo-site its the same thing…
    #974972
    I make a test on the demo site .
    I opened the Menu Joomla pages > There is dropdown > I clicked on Login
    And it redirects me to the login page , there is no issue noticed .
    Kindly provide us a screencast or step screenshot so that i can understand about the exact issue you are facing .
    hdsports Friend
    #975017
    but when you "CLICK" on "Joomla Pages" the site http://purity-iii.demo.joomlart.com/index.php/joomla-pages opens.
    But i want, after a click on the Menu-Point "joomla Pages" that only the Sub-Menu opens and not another site.
    #975033
    You have use the menu type text separate so it does not have any links, at present the Menu type is redirect the page to its destination .
    hdsports Friend
    #975056
    no, before update with 1 click the submenu opens, with doubleclick the site loads the top-menupoint.
    dont know why after the update these setting are overwritten…
    #975153
    Its very hard to assume the issue , since the template is working same like demo site .
    You can install the backup of site on a subdomain and compare it with it .
This topic contains 9 replies, has 2 voices, and was last updated by  Pankaj Sharma 8 years, 2 months ago.
