  • rhante Friend
    #162811
    I have 2 Problem.
    1- i used 32×32 icons at menu. And the space between icon and menu name is not enough. How can i adjust it?
    2- how to change the product name to under the picture? OR how to reduce the space between picture and name?
    Ty for reply
    1. problem
    himangi Friend
    #386530
    For menu issue, please refer to http://www.joomlart.com/forums/topic/how-to-move-text-to-right-after-inserting-a-bigger-image-in-mega-menu/
    In your case, you need to use <blockquote>span.has-image</blockquote> instead of <blockquote>div.megacol span.has-image</blockquote>. div.megacol is required if you are styling menuitems with images in the megamenu columns..
    rhante Friend
    #386534
    there is no code on template.css like this
    div.megacol span.has-image {
    background-position: left 1px;
    background-repeat: no-repeat;
    display: block;
    overflow: hidden;
    padding-left: 40px;
    any idea?
    himangi Friend
    #386540
    That is the additional code you need to put in template.css to override the current styling of the image icons with respect to menu item links.
    As I said before you need not use <blockquote>div.megacol</blockquote>
    you need to use <blockquote>span.has-image {
    display: block;
    overflow: hidden;
    padding-left: 40px;
    } </blockquote>
    rhante Friend
    #386555
    <em>@himangi 234424 wrote:</em><blockquote>That is the additional code you need to put in template.css to override the current styling of the image icons with respect to menu item links.
    you need to use</blockquote>
    TY done it.
    And still have problem 2
    himangi Friend
    #386558
    A ticket has been raised for the 2nd problem.
    #386642
    Dear rhante,
    in this module,each product item (including product image,title…) were rendered by the core virtuemart component,If you want to change the order (for example the title go under the image) then the change will be applied for other parts ( virtuemart categories..).
    So do you want to make this change ?
    rhante Friend
    #386667
    <em>@dathq 234551 wrote:</em><blockquote>Dear rhante,
    So do you want to make this change ?</blockquote>
    ya. i do.
    its not important, all product should have same format.
This topic contains 8 replies, has 3 voices, and was last updated by  rhante 13 years, 9 months ago.
