  • robosavvy Friend
    #185991
    When i test my website on a mobile ( iPhone for example ) it puts the menu on a dropdown. When i click and select a menu it slides down but don’t go to the selected #id .
    What can be wrong?
    Could you pm me admin and FTP account of your site? Please backup your site and I shall check this for you. 🙂
    mdiscenzo Friend
    #487505
    Very interested in the result of this. There’s another thread where a couple people are asking this question, and asking for a fix. something with the scrollspy offset is my guess. Did you find a solution to this!?
    PM me url, admin and FTP account of your site, I shall try to check for you.
    Backup your site first and update these 2 following files to appropriate folders:
    – /templates/ja_onepage(your default template/js/script.js
    – /templates/ja_onepage(your default template/tpls/blocks/header.php
    then let me know the result.
    1. script.zip
    2. header.zip
This topic contains 5 replies, has 3 voices, and was last updated by  Saguaros 11 years, 9 months ago.
