sakari Friend
sakari
- February 2009
- 15 times in 1 posts
January 17, 2011 at 10:49 pm #158907Hello friends,
I do not know whether this is a template topic, or rather a general theme is Joomla!
I try to add the menu, it get so!
I’ve tinkered with PhotoShop Sun as I imagine!Is that possible?
If so, how?I get not going there, can you help me there?
Thank you
Best regards
Sakari
- November 2014
- 3854 times in 3563 posts
January 18, 2011 at 7:38 am #372365dear sakari,
Please provide link to your site too.
sakari Friendsakari
- February 2009
January 18, 2011 at 9:46 am #372400Hi,
this site is always under construction to run on your corporate intranet!
And apart from this menu choices do not exist, I just wanted shown how to create it!🙂
sakari Friendsakari
- February 2009
January 30, 2011 at 2:48 am #374439I can not really give an answer?
At least if it works or not!Thank you very much!
🙂Ninja Lead ModeratorNinja Lead
- November 2014
February 1, 2011 at 11:03 am #374718hi sakari,
please do as following:
below Community menu item, add 2 subitem:
1. choice of
2. logininside “choice of”, continue creating its sub items, that are: video, photo, group, event, inbox
with the “login” menu item, choose item type as “Separator” then put the login module into it.
I also want to let you know its not possible to have the “choice” label to cover 2 subitems as you drawed, but each should have it own label above intead.
please spend a little time studying mega-menu, you will find it pretty easy.
Hop that helps.AuthorPostsViewing 5 posts - 1 through 5 (of 5 total)This topic contains 5 replies, has 2 voices, and was last updated by Ninja Lead 13 years, 11 months ago.
Menu display problem!
