hbic Friend
hbic
- June 2015
- 6 times in 1 posts
August 11, 2015 at 9:06 pm #659962I have a menu I want to display as button choices at the top of my Uber website. The site was installed with the Application Site from quick start. I’ve attached 2 files, one of the main page showing the vertical buttons, and one of the module where I attempt to use nav-pills to make the button horizontal.
Everthing I Google says this should work, but it doesn’t. I’ve tried a space before ‘nav-pills’, nada.
hbic Friendhbic
- June 2015
August 13, 2015 at 3:25 pm #660897I created a custom.css file and added the code you pasted. I must be doing something wrong, because it’s not taking.
Update: I was trying to use the Joomla interface to edit the file and I couldn’t seem to get the right file created in the right spot. I access the filesystem of the server directly, created the file and added your snippet. It works, but the button are out of whack, a bit. The button on the left is a slight bit higher that the others.
Any idea why those buttons would be crooked?
hbic Friendhbic
- June 2015
August 13, 2015 at 3:25 pm #745371I created a custom.css file and added the code you pasted. I must be doing something wrong, because it’s not taking.
August 14, 2015 at 5:43 am #661067Hi generally you need to create new position to add items , as there is not much space .
above solution is work as tweak . to adjust first item add this code :
.right-menu .nav li.item-665 {padding-top:7px!important;}
Hope it helps .
This topic contains 5 replies, has 2 voices, and was last updated by hbic 9 years, 2 months ago.
