billo0071 Friend
billo0071
- November 2016
- 3 times in 3 posts
May 5, 2017 at 2:17 am #1031275Menus work fine on android and pc but ipad they are not clickable.
http://1clicksolutions.ca/new/index.php/en/Saguaros ModeratorSaguaros
May 5, 2017 at 7:54 am #1031371Hi,
It’s weird, could you share the login info of your site so I will take a look?
billo0071 Friendbillo0071
- November 2016
May 5, 2017 at 2:53 pm #1031483This reply has been marked as private.Saguaros ModeratorSaguaros
May 8, 2017 at 1:52 am #1031812There seems to be problem of Text Separator menu item type in iPad device specific so you can’t click. I will pass to the team for further checking.
- November 2016
May 10, 2017 at 6:55 pm #1033007What is happening with this issue? Before I was told that the only way to open subemnus was if the parent was just a text separator, which is not correct as I have many rockethteme templates where submenu works even if the parent is not a text separator menu item. Now whole menu does not work on apple devices, I am almost ready to make this site live but I need the menu system fixed.
May 11, 2017 at 2:45 am #1033072Hi,
The team is working on it and it will be fixed pretty soon.
Pls stay tuned.
- November 2016
May 19, 2017 at 2:35 am #1035249I reported this issue 2 weeks ago and still no fix. When can I expect this issue to be fixed?
- November 2016
May 20, 2017 at 2:21 am #1035538I thought if we paid for builder we would get priority support, what happened? I also can’t believe that no one else is complaining about this issue.
This topic contains 8 replies, has 2 voices, and was last updated by Saguaros 7 years, 7 months ago.
