cohibadad Friend
cohibadad
- November 2011
August 17, 2012 at 7:32 pm #180003I have had a few minor problems with the Community Plus template:
1. The Menu Module that appears blue on demo site. If the template is changed to left-content-right, or the menu module is moved to a position other than left, the blue mod is lost. Is there a way to retain the blue appearance in these other positions or configurations? Is there any other color options other than blue? I have tried others such as green, red but to no effect.
2. The typography highlight on some demos shows different color highlighting for -1, -2, -3 options but these all appear as yellow highlighting on the demo and my site. Are the other highlight options no longer functional?
3. JA typo extension does not appear to work with this template. Am I correct?
Thanks,
Darin 🙂
Stork11 FriendStork11
- March 2011
- 431 times in 393 posts
August 20, 2012 at 3:38 am #464681Hello cohibadad,
Would you mind getting me a few screenshots of 1st and 2nd problems for more clarifications? Then I shall know what you are trying to achieve.
Right now, I am quite not sure where to start.Regards.
1 user says Thank You to Stork11 for this useful post
cohibadad Friendcohibadad
- November 2011
August 22, 2012 at 9:22 pm #465028Hello Stork11,
1. The blue main menu module on the home page shows up as blue if in the default position of the demo (which is left) with the layout being content-left-right:
but if the menu module is set to another position (e.g. user5) it loses its blue background/shape:
or if it remains in the left position but the layout is changed to left-content-right it appears:
2. On http://templates.joomlart.com/ja_community_plus/typography.html the different highlighting options (-1, -2, -3) show up as different colors:
but on the community plus 2.5 live demo (http://joomla25-templates.joomlart.com/ja_community_plus/typography.html) and on my localhost site all highlighting (-1,-2 and -3) shows up as yellow:
Thanks,
Darin
- Stork11 Friend
Stork11
- March 2011
August 24, 2012 at 3:52 am #465150Hello Darin,
For 1st problem, it’s style of template. Style is different from each position.
For 2nd, what did you mean when you said “highlighting options (-1, -2, -3)”? I can see typography is the same on “template” and “demo” link.
Please re-check it.
Regards.
- November 2011
August 24, 2012 at 11:43 pm #465275Thanks Stork,
So it is not possible to have the same style in the same position (ie left) if the layout is changed from content-left-right to left-content-right? And the template link shows 3 different colored highlight colors (yellow, green, blue) while the demo link shows a different yellow color. Do your links not look like my included screenshots?
Thanks,
Darin
- March 2011
August 25, 2012 at 3:29 am #465287<em>@cohibadad 335820 wrote:</em><blockquote>Thanks Stork,
Thanks,
Darin</blockquote>
Hello cohibadad,Here is my screenshots for j15 and j25.
Joomla 1.5Joomla 2.5
As you see, both are the same styles.
Regards.
cohibadad Friend
cohibadad
- November 2011
August 26, 2012 at 8:35 pm #465383Hello Stork11,
Your screenshots show the same as mine. The first has 3 different colors of highlighting while the second has just yellow highlighting. If you look at the html, both have the same 3 highlighting options highlight-1,-2 and -3 but the first displays as 3 different colors and the second displays all 3 as yellow.
Darin
- March 2011
August 27, 2012 at 2:19 am #465395<em>@cohibadad 335978 wrote:</em><blockquote>Hello Stork11,
Darin</blockquote>
Hello Darin,You can add “!important” after “highlight-1,-2,-3” as below to fix this issue:
.highlight-1 {
background: none repeat scroll 0 0 #FDF6CA !important;
}Regards.
Viewing 8 posts - 1 through 8 (of 8 total)This topic contains 8 replies, has 2 voices, and was last updated by Stork11 12 years, 4 months ago.
Menu Module and highlight typography and JA typo
