  • kunoichidee Friend
    #180950
    I might just be looking over the way this template works, but I can’t figure it out.
    In the main menu on top I have a link to a single article.
    On the right side of that article a menu module is showing with other links. (I also tried it with a custom html modules with links).
    When I click on a link in the that menu module it shows the correctly linked article but the menu module is gone.
    To add to the information; the articles linked in that menu module on the side are not linked to any other (main / top) menu.
    How do I set this up that the side module also shows when any of the linked articles of that menu are displayed?
    Thanks for your help.
    Diana
    Stork11 Friend
    #468157
    Hello kunoichidee,
    You need to set your article linking to a menu item, then set the menu module (custom module) to show on that menu. It’s feature of Joomla.
    Regards.
This topic contains 2 replies, has 2 voices, and was last updated by  Stork11 12 years, 2 months ago.
