  • blackeaglece Friend
    #182737
    Hi I’ve created new profile in template manager (green-uk) but the tab where I can choose the menu is disabled and I can not the choose the uk menu. Where can I do?
    Thank you
    Could you please send me via PM your admin login details ?
    So i can better check your problem – the info provided above are not enough to give a solution
    blackeaglece Friend
    #474883
    <em>@pavit 348769 wrote:</em><blockquote>Hi
    So i can better check your problem – the info provided above are not enough to give a solution</blockquote>
    Ops I solved Thank you
    agussol Friend
    #488013
    I have a similar problem here.
    I have setup a 4 language website using last version of Ironic.
    The problem is I have to choose a menu into the template, so while I activate multilingual and want to change the language, the menu disapears.
    In fact, seems if the module position should be affected using native J! system instead of selecting it into template it should work ?
    Maybe it requires a different layout into the template for each language too?
    Checked the manual here :
    http://www.joomlart.com/forums/topic/userguide-ja-ironis-template-for-joomla-2-5/
    But didn’t find any multilingual help.
    Thanks for your help !
    Did you ever try follow guide of joomla about multilanguage: http://help.joomla.org/files/EN-GB_multilang_tutorial.pdf ?
    agussol Friend
    #488301
    Thanks, I tried different tutorials, and this one helps me configuring a copy for each template for each language, but I still have my menu not reloaded into the top mainnav.
    See here :
    http://www.sds.univ-montp2.fr
    Thanks for any advice !
    agussol Friend
    #488470
    Any clue ? Thanks !
    swissa Friend
    #488471
    <em>@agussol 367053 wrote:</em><blockquote>Any clue ? Thanks !</blockquote>
    You can try these two threads..
    http://www.joomlart.com/forums/topic/2-multilingual-queries/
    http://www.joomlart.com/forums/topic/multi-language-options-clarification/#post-465132
    agussol Friend
    #488472
    Lovely, it works using the first thread !
    I did not previously noticed the menu for languages on the left !!! I was duplicating templates assigning them on each language…
    Thanks for your help Swissa !
This topic contains 9 replies, has 5 voices, and was last updated by  agussol 11 years, 7 months ago.
