  • georgios Friend
    #128815
    I joomla 1.0.x and this template on my site
    Only when I insert a video in an article, the contents of my Sec (video then) goes above the pull-down menus (css or moo in the configuration).
    What can I do?
    #250236
    It’s best if you send link of your site . It’s problem of z-index Please open menu css file try to edit z-index property of it.
    georgios Friend
    #250242
    Thank you very much for your response
    Sorry but I can not tell you the address of the site because it is locally for now (not yet online).
    I enclose a copy of the screen problem.
    I really do not know what it is variable; below contents of the file that is the origin
    Thank you for your help …
    COntenu index.php file of templates (if you have enough information in it; you also want to cut and paste files css?)
    <?php
    * @copyright Copyright (C) 2005 – 2007 Open Source Matters. All rights reserved.
    * @license GNU/GPL, see LICENSE.php
    * Joomla! is free software. This version may have been modified pursuant
    * to the GNU General Public License, and as distributed it includes or
    * is derivative of works licensed under the GNU General Public License or
    * other free or open source software licenses.
    * See COPYRIGHT.php for copyright notices and details.
    // no direct access
    defined( ‘_VALID_MOS’ ) or die( ‘Restricted access’ );
    defined( ‘DS’) || define( ‘DS’, DIRECTORY_SEPARATOR );
    include_once (dirname(__FILE__).DS.’/ja_vars.php’);
    <!DOCTYPE html PUBLIC “-//W3C//DTD XHTML 1.0 Transitional//EN” “http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd”>
    <html xmlns=”http://www.w3.org/1999/xhtml”>
    <head>
    <?php mosShowHead(); ?>
    <script language=”javascript” type=”text/javascript” src=”<?php echo $tmpTools->templateurl(); ?>/js/mootools.v1.11.js”></script>
    <link rel=”stylesheet” href=”<?php echo $tmpTools->baseurl(); ?>templates/system/css/system.css” type=”text/css” />
    <link rel=”stylesheet” href=”<?php echo $tmpTools->baseurl(); ?>templates/system/css/general.css” type=”text/css” />
    <link rel=”stylesheet” href=”<?php echo $tmpTools->templateurl(); ?>/css/template_css.css” type=”text/css” />
    <script language=”javascript” type=”text/javascript” src=”<?php echo $tmpTools->templateurl(); ?>/js/ja.script.js”></script>
    <!– Menu head –>
    <?php $jamenu->genMenuHead(); ?>
    <link href=”<?php echo $tmpTools->templateurl(); ?>/css/colors/<?php echo $tmpTools->getParam(JA_TOOL_COLOR); ?>.css” rel=”stylesheet” type=”text/css” />
    <style type=”text/css”>
    .clearfix {height: 1%;}
    img {
    border: none;
    </style>
    .clearfix {display: inline-block;}
    </style>
    <?php if ($tmpTools->isIE6()) { ?>
    var siteurl = ‘<?php echo $tmpTools->baseurl();?>’;
    window.addEvent (‘load’, makeTransBG);
    function makeTransBG() {
    makeTransBg($E(‘h1.logo a’));
    makeTransBg($$(‘img’));
    makeTransBg ($$(‘#ja-cssmenu li ul’), ”, ‘scale’, 0, 2);
    </script>
    #ja-cssmenu li ul li {
    background:transparent url(<?php echo $tmpTools->templateurl(); ?>/images/blank.png) no-repeat right;
    </style>
    <?php } ?>
    #ja-header {
    padding-left: 0px;
    #ja-mainnav {
    padding-left: 200px;
    #ja-subnav {
    #ja-container,
    #ja-botsl,
    #ja-footer {
    width: <?php echo $tmpWidth; ?>;
    margin: 0 auto;
    </style>
    </head>
    <body id=”bd” class=”<?php echo $tmpTools->getParam(JA_TOOL_SCREEN);?> fs<?php echo $tmpTools->getParam(JA_TOOL_FONT);?>” >
    <a name=”Top” id=”Top”></a>
    <ul class=”accessibility”>
    <li><a href=”#ja-content” title=”Skip to content”>Skip to content</a></li>
    <li><a href=”#ja-mainnav” title=”Skip to main navigation”>Skip to main navigation</a></li>
    <li><a href=”#ja-col1″ title=”Skip to 1st column”>Skip to 1st column</a></li>
    <li><a href=”#ja-col2″ title=”Skip to 2nd column”>Skip to 2nd column</a></li>
    <li><a href=”#ja-col3″ title=”Skip to 3nd column”>Skip to 2nd column</a></li>
    </ul>
    <div id=”ja-wrapper”>
    <!– BEGIN: HEADER –>
    <div id=”ja-headerwrap”>
    <div id=”ja-header” class=”clearfix”>
    <?php
    $siteName = $tmpTools->sitename();
    if ($tmpTools->getParam(‘logoType’)==’image’) { ?>
    <h1 class=”logo”>
    <a href=”index.php” title=”<?php echo $siteName; ?>”><span><?php echo $siteName; ?></span></a>
    </h1>
    <?php } else {
    $logoText = (trim($tmpTools->getParam(‘logoText’))==”) ? $siteName : $tmpTools->getParam(‘logoText’);
    $sloganText = (trim($tmpTools->getParam(‘sloganText’))==”) ? ‘SITE SLOGAN’ : $tmpTools->getParam(‘sloganText’); ?>
    <h1 class=”logo-text”>
    <a href=”index.php” title=”<?php echo $siteName; ?>”><span><?php echo $logoText; ?></span></a>
    </h1>
    <p class=”site-slogan”><?php echo $sloganText;?></p>
    <?php } ?>
    <?php if(mosCountModules(‘user4’)) : ?>
    <div id=”ja-search”>
    <?php mosLoadModules(“user4”, -1); ?>
    </div>
    <?php endif; ?>
    <?php if (mosCountModules(‘top’)) { ?>
    <div id=”ja-login”>
    <?php mosLoadModules(“top”,-1); ?>
    </div>
    <?php } ?>
    <!– BEGIN: MAIN NAVIGATION –>
    <div id=”ja-mainnav” class=”clearfix”>
    <?php $jamenu->genMenu (0); ?>
    </div>
    <!– END: MAIN NAVIGATION –>
    </div>
    </div>
    <!– END: HEADER –>
    <?php if ($hasSubnav) { ?>
    <div id=”ja-subnavwrap”>
    <div id=”ja-subnav” class=”clearfix”>
    <?php $jamenu->genMenu (1,1); ?>
    </div>
    </div>
    <?php }else if($ja_menutype == 4){
    </div>
    </div>
    <?php } ?>
    <div id=”ja-containerwrap<?php echo $divid; ?>”>
    <div id=”ja-container” class=”clearfix”>
    <div id=”ja-mainbody”>
    <!– BEGIN: CONTENT –>
    <div id=”ja-content”>
    <div class=”ja-innerpad”>
    <div id=”ja-slider”>
    <?php mosLoadModules(‘slider’, -2); ?>
    </div>
    <?php if(!$tmpTools->isFrontPage()) : ?>
    <div id=”ja-breadcrumb”>
    <?php mosPathway(); ?>
    </div>
    <?php endif ; ?>
    <?php mosMainBody(); ?>
    <?php if(mosCountModules(‘banner’)) : ?>
    <div id=”ja-banner”>
    <?php mosLoadModules(“banner”, -1); ?>
    </div>
    <?php endif; ?>
    </div>
    </div>
    <!– END: CONTENT –>
    <?php if ($ja_left) { ?>
    <!– BEGIN: LEFT COLUMN –>
    <div id=”ja-col1″>
    <?php mosLoadModules(“left”, -2); ?>
    </div><br />
    <!– END: LEFT COLUMN –>
    <?php } ?>
    </div>
    <?php if ($ja_right) { ?>
    <!– BEGIN: COLUMNS –>
    <?php if (mosCountModules(‘mass_top’)) { ?>
    <div id=”ja-masstop” class=”clearfix”>
    <?php mosLoadModules(“mass_top”, -2); ?>
    </div>
    <?php } ?>
    <?php if (mosCountModules(‘right1’) or mosCountModules(‘right2’)) { ?>
    <div id=”ja-colswrap” class=”clearfix colw<?php echo (mosCountModules(‘right1’) and mosCountModules(‘right2’)); ?>”>
    <div class=”ja-innerpad clearfix”>
    <?php if (mosCountModules(‘right1’)) { ?>
    <div id=”ja-col2″>
    <?php mosLoadModules(“right1”, -2); ?>
    </div>
    <?php } ?>
    <?php if (mosCountModules(‘right2’)) { ?>
    <div id=”ja-col3″>
    <?php mosLoadModules(“right2”, -2); ?>
    </div>
    </div>
    <?php } ?>
    </div>
    </div><br />
    <?php } ?>
    <?php if (mosCountModules(‘mass_bot’)) { ?>
    <div id=”ja-massbot” class=”clearfix”>
    <?php mosLoadModules(“mass_bot”, -2); ?>
    </div><br />
    <?php } ?>
    <!– END: COLUMNS –>
    <?php } ?>
    </div>
    </div>
    <?php
    $spotlight = array (‘user1′,’user2′,’user5′,’user6′,’user7’);
    $botsl = $tmpTools->calSpotlight ($spotlight,99.9);
    if( $botsl ) {
    <!– BEGIN: BOTTOM SPOTLIGHT –>
    <div id=”ja-botslwrap”>
    <div id=”ja-botsl” class=”clearfix”>
    <?php if( mosCountModules(‘user1’) ) {?>
    <div align=”center” class=”ja-box<?php echo $botsl[‘user1’][‘class’]; ?>” style=”width: <?php echo $botsl[‘user1’][‘width’]; ?>;”>
    <?php mosLoadModules(“user1”, -2); ?>
    </div>
    <?php } ?>
    <?php if( mosCountModules(‘user2’) ) {?>
    <div align=”center” class=”ja-box<?php echo $botsl[‘user2’][‘class’]; ?>” style=”width: <?php echo $botsl[‘user2’][‘width’]; ?>;”>
    <?php mosLoadModules(“user2”, -2); ?>
    </div>
    <?php } ?>
    <?php if( mosCountModules(‘user5’) ) {?>
    <div align=”center” class=”ja-box<?php echo $botsl[‘user5’][‘class’]; ?>” style=”width: <?php echo $botsl[‘user5’][‘width’]; ?>;”>
    <?php mosLoadModules(“user5”, -2); ?>
    </div>
    <?php } ?>
    <?php if( mosCountModules(‘user6’) ) {?>
    <div align=”center” class=”ja-box<?php echo $botsl[‘user6’][‘class’]; ?>” style=”width: <?php echo $botsl[‘user6’][‘width’]; ?>;”>
    <?php mosLoadModules(“user6”, -2); ?>
    </div>
    <?php } ?>
    <?php if( mosCountModules(‘user7’) ) {?>
    <div align=”center” class=”ja-box<?php echo $botsl[‘user7’][‘class’]; ?>” style=”width: <?php echo $botsl[‘user7’][‘width’]; ?>;”>
    <?php mosLoadModules(“user7”, -2); ?>
    </div>
    <?php } ?>
    </div>
    </div>
    <!– END: BOTTOM SPOTLIGHT –>
    <?php } ?>
    <!– BEGIN: FOOTER –>
    <div id=”ja-footerwrap”>
    <div id=”ja-footer” class=”clearfix”>
    <div id=”ja-footnav”>
    <?php mosLoadModules(“user3”, -1); ?>
    </div>
    <div class=”copyright”>
    <?php mosLoadModules(“footer”, -1); ?>
    </div>
    <div class=”ja-cert”>
    <?php mosLoadModules(“syndicate”); ?>
    <a href=”http://jigsaw.w3.org/css-validator/validator?uri=<?php echo urlencode($tmpTools->getLiveSiteURL());?>” target=”_blank” title=”CSS Validity” style=”text-decoration: none;”>
    <img src=”<?php echo $tmpTools->templateurl(); ?>/images/but-css.gif” border=”none” alt=”CSS Validity” />
    </a>
    <a href=”http://validator.w3.org/check/referer” target=”_blank” title=”XHTML Validity” style=”text-decoration: none;”>
    <img src=”<?php echo $tmpTools->templateurl(); ?>/images/but-xhtml10.gif” border=”none” alt=”XHTML Validity” />
    </a>
    </div>
    </div>
    </div>
    <!– END: FOOTER –>
    </div>
    <?php mosLoadModules(“debug”, -1); ?>
    </body>
    </html>
    1. pb-website-css
    georgios Friend
    #250854
    Good morning,
    Do you have any ideas for me?
    I am embarrassed …
    #250977
    Hi georgios !
    It ‘s difficult because i couldn’t look into your site ->so , I couldn’t show and check your problem.
    georgios Friend
    #251008
    The site is not online, I must make it functional demonstration before …
    I have this problem with IE 7 / 8 but not with firefox
    I am surprised that nobody else’ve had this problem …
    georgios Friend
    #253918
    nobody would have an idea for a user desespered?
    Otherwise I now temporary address that shows the problem:
    example: http://www.fftarot.fr/v2/component/option,com_wrapper/Itemid,248/
    You can see especially if you follow the link: “communiquer>audiovisuel>stages” !
    Thank you very much …
    Menalto Friend
    #253920
    What is the flash content on this link here:
    http://www.fftarot.fr/v2/component/option,com_wrapper/Itemid,255/
    Is it from a module or from a extern link outside yoru site?
    georgios Friend
    #253925
    Yes,
    in fact when you scroll down the menu with the mouse, the menu falls below images. I have this problem on all videos and some images …
    So for certain content, it can be a wrapper (from our site for the link in question), for others it may be a module or a simple via a video called mambot.
    thank you a lot of worry me …
    georgios Friend
    #254175
    snif :((
    an idea??
    georgios Friend
    #254777
    Still no ideas?
    Otherwise I may be another bug easier (?).
    If I display this template (see url) on a large screen, the tabs mainmenu of the most right shifts in the content below and passes over the position user4.
    Frankly and it is rare (and sorry but…): I did not really go out with this template while I never have a problem with other publishers (which I do not quote out of politeness :-[)
    #254806
    Hi.
    Plz send me source(source page HTML) of page what embed video in content, because you haven’t a link, so it’s very difficult for us to help you.
    georgios Friend
    #254886
    Good morning,
    It’s very simple. I solved the problem by changing my methods link on menus because I need to show that it works …
    This bug exists on the pages that contain for example:
    — A wrapper
    — Some components as seyret videos
    — An image content (eg module rok image that is now home to the left, since I can not publish it on the right for this problem menu)
    On this page for example
    http://www.fftarot.fr/v2/component/option, com_wrapper / Itemid, 257 /
    But I inserted a module at the top of the wrapper to hide the problem of the menu! (I can show you the bug online but I can not leave a very long time on the screen, and I do not know when you log)
    To see the image problem, see attached image on previous messages.
    Finally, I have this important issue size template on large screens. The template does not fit so well that on a large screen, it magnifies everything and shifts everything right down!
    Thank you
This topic contains 13 replies, has 3 voices, and was last updated by  georgios 16 years, 6 months ago.
