  • spanta Friend
    #193410
    I start using this template for a previous made site. The menu system has coloring problems.
    The first layer works fine but with submenus (second layer) the text & background color are the same so you can not read them
    cssyeah Moderator
    #517169
    Hi spanta,
    All menu items and sub menu is working fine on our demo. Can you provide us the screenshot of this issue or post your url here? We will help you check this issue and give you a solution.
    miku Friend
    #517243
    Hello, I had same problem when I disabled Megamenu.When I turned it on again it all works fine again.
    Css Magician Friend
    #517249
    @ spanta, miku
    It is JA Bookshop’s bug when megamenu is disabled. We will commit the fix in next update for this template.
    Meanwhile, please apply the following quick fix:
    – Open templates/ja_bookshop/css/custom.css file (create such new file if it doesn’t exist) and add CSS rule below:
    .navbar-nav .dropdown-menu {
    background: #333;
    .navbar-nav .dropdown-menu > li > a {
    color: #fff;
    font-family: 'Roboto Slab',Georgia,Times,serif;
    .navbar-nav .dropdown-menu > li > a:hover,
    .navbar-nav .dropdown-menu > li > a:focus,
    .navbar-nav .dropdown-menu > li > a:active {
    background: none;
    color: #F0141E;
    .navbar-nav .dropdown-menu > li.open > a,
    .navbar-nav .dropdown-menu > li.active > a {
    background: none;
    color: #F0141E;
    Hope that helps.
This topic contains 4 replies, has 4 voices, and was last updated by  Css Magician 11 years ago.
