July 17, 2012 at 10:55 am #179158
Hallo,
I am working local:
I want create a normal menu like this – please look my picture):menu:
K2 Blog style
Landeskunde (K2-categories)
–>Königshaus (K2-categories)
—->Der König (K2-item)
user pageIt looks strange and i not have a clue
what I did wrong.thank you for your help
Josef
Saguaros ModeratorSaguaros
July 18, 2012 at 8:22 am #461273Hi Josef,
Please tell me step by step to create this menu item so that I can reproduce this issue in my local. It’s hard for me without seeing problem directly. Hope you understand me.
July 18, 2012 at 9:01 am #461281Sorry,
Is their some help?
Where can I correct this K2-menu in ja_wall,
temlate=default.Thank you!
JosefJuly 18, 2012 at 9:34 am #461292Hallo Saguaros,
thank you for your respons.Ok.
I did what I did a hundreds of times before.1.
I took your default Topmenue of ja_wall
and changed it.
Please look picture.
2.
The mod_modul is like always
3.
But the Frontend ist not correct.
The module works well, but the
Submenu-items are not in place.
Please look picture.It looks like it is a css problem.
But I do not know how to
solve it.best regards
Josef- rcheesley Friend
rcheesley
- January 2008
August 5, 2012 at 6:19 pm #463231I have the same problem, I have posted on this forum message:
http://www.joomlart.com/forums/topic/drop-down-top-menu/
Did you resolve this?Ruth
August 6, 2012 at 3:05 am #463272Hi there,
As in my colleague’s reply, JA Wall does not come with JA T3 Framework so it will not support Megamenu. And JA Wall only support maximum 2 levels due to the limited of responsive feature and consistent menu display on all devices. Hope you understand us.
rcheesley Friendrcheesley
- January 2008
August 17, 2012 at 8:27 am #464517Thanks for clarifying this, it’s disappointing as other templates I use from JA have good menu structures on mobiles more than 2 deep 🙁 This should be made clear on the JA Wall demo in my opinion, it is in no way obvious.
Ruth
August 17, 2012 at 10:29 am #464543Thanks for your idea, we shall update in JA Wall Q&A thread
Regards.
AuthorPostsViewing 8 posts - 1 through 8 (of 8 total)This topic contains 8 replies, has 3 voices, and was last updated by Saguaros 12 years, 4 months ago.
