  • paulk Friend
    #205571
    We are looking at JA University template http://ja-university.demo.joomlart.com/index.php/en/ in IE10 with compatibility mode turned on and found few menu issues ( A horizontal black bar with two squares on either ends, clicking on the black square shows the menu items in a drop down).
    I am wondering if its possible to change the menu items to appear with out having to click these squares.
    Any suggestions on how to change this would be highly appreciated.
    Also can we use different styled/themed menus instead of this.
    Thanks.
    Ninja Lead Moderator
    #567351
    I checked it on IE10 but I could not get that bug. Can you give me the screenshot this bug? I will check it further.
This topic contains 2 replies, has 2 voices, and was last updated by  Ninja Lead 9 years, 7 months ago.
