  • ragtim Friend
    #123526
    Hello all. I am not sure if this is a Template issue or a Transmenu issue but the menus don’t work right when I have SEF enabled. If i go to the regular menu link and click “library” it goes to the proper blog view layout (http://www.site.com/test2), but when I try to go to the transmenu, suckerfish menu, etc… the link is (http://www.site.com/test2/13). Basically it looks like it is added the category id onto the link.
    Khanh Le Moderator
    #231942
    Which SEF component do you use? Those menu often work fine with most sef component.
This topic contains 2 replies, has 2 voices, and was last updated by  Khanh Le 17 years ago.
