  • cavijayan Friend
    #123961
    Im using Hedera in the following test site: http://www.canberrasec.net/beta2/index.php
    When you use the menu “About School” – “School Advisory Committee”
    the menu shows a line also breaks into two lines.
    Problem appears with both IE 6 / 7 as well as Firefox.
    Is anyone else have this problem?
    Any fixes?
    Menalto Friend
    #233302
    Can you try to open up ja-sosdmenu.css on line 68:
    #ja-cssmenu ul a {
    width:10.8em;
    And change it to:
    #ja-cssmenu ul a {
    width:13em;
    cavijayan Friend
    #233349
    Thanks that solved my problem
This topic contains 3 replies, has 2 voices, and was last updated by  cavijayan 17 years, 1 month ago.
