Sherlock
- 2478 times in 2162 posts
August 1, 2008 at 3:52 am #131629Hi alll !
I have spent 30 minutes to modify layout of Mesolite 1.5 , convert it from 2 colums layout (left + body ) to 3 columns layout ( left + body + right ) . I have edit 4 file in Mesolite templates :1. index.php file in templatesja_mesolite folder.
2. ja_vars_1.5.php file in templatesja_mesolite folder.
3. template.css file in templatesja_mesolitecss folder.
4. ja.script.js file in templatesja_mesolitejs folder.If you use quickstart package you need change width of slideshow module and vmproductslide module after update obove files :
– you must go to admin >> module manager >> select slideshow module –> set width of it to from “760px” to “565px”.
– With vmproductslideshow module, change number element from “4” to “3”.
9 users say Thank You to Sherlock for this useful post
beyondsports Friendbeyondsports
- May 2008
- 2 times in 1 posts
August 1, 2008 at 2:10 pm #263435hainn…. what specifically did you change in the template.css file… reason being on my end i have edited that file heavily… if you can tell me exactly what you changed i can just copy and paste the change’s into my file…
thanks again
treybeyondsports Friendbeyondsports
- May 2008
August 1, 2008 at 3:08 pm #263443nevermind hainn…i went line by line and made the change’s… appreciate the patch…
thanks
treyonce i ftp the site ill post for review’s..
thanks again!!!1beyondsports Friendbeyondsports
- May 2008
August 3, 2008 at 1:43 pm #263604hainn can you publish a page detailing the layout of this template… showing each mod position…please look at the post i made about the featured product and ja news…
treysoulja Friendsoulja
- November 2006
- 1 times in 2 posts
August 3, 2008 at 2:01 pm #263608I have a problem, default frontpage is again hidden like it was in 1 version of template.
- May 2008
August 3, 2008 at 2:08 pm #263610yeas soulja i have posted for 2 days trying to find out how to enable the frontpage…which i want to use instead of ja news….
- November 2006
August 3, 2008 at 3:25 pm #263614yeap, i saw at your page you had decided this problem. Can you share your exoerience ?
- May 2008
August 3, 2008 at 3:27 pm #263615still waiting on a reply to help me out…
August 3, 2008 at 10:03 pm #263644Hi there,
Your 3-col modification is not compaitble with some popular joomla components…
like hwdVideoShare – Share videos on your website
- May 2008
August 3, 2008 at 10:37 pm #263647manindersingh i am just trying to enable the default frontpage for joomla instead of ja news…and move the featured products down into the ja news mod position or just unpublish it altogether…
any idea’s
thanks
trey1 user says Thank You to beyondsports for this useful post
Sherlock FriendSherlock
August 4, 2008 at 1:53 am #263663Hi all !
To display default frontpage joomla instead of ja news :
Open index.php file in templates/ja_mesolite folder, find following code section :
<?php if($tmpTools->getParam('showFrontPage') || !$tmpTools->isFrontPage()) : ?>
<div id="ja-content" class="clearfix">
<jdoc:include type="component" />
</div>
<?php endif; ?>
change to :
</div>
1 user says Thank You to Sherlock for this useful post
- May 2008
August 4, 2008 at 2:12 am #263668hainn thanks… appreciate it… made the change’s and working great… can you help on another issue i am having… here is the url for my site:
http://www.maeseducationcenter.com/maes%20mesolite/
i need to either drop the featured products module below where the frontpage content is or just disable it altogether… in my case i really dont need it with the slideshow of products offered…
please let me know what else i need to do and thanks again!!!!
- November 2006
August 4, 2008 at 11:15 am #263745code wasn’t exactly the same to find. But idea was clear. it works. thank you
soulja Friendsoulja
- November 2006
August 4, 2008 at 12:07 pm #263748another problem, can’t change height of slideshow. i put 152 px and there is emty space beetween slideshow and product slideshow. i attached screenshot.
- May 2008
August 4, 2008 at 12:14 pm #263749soulja go into the vm slideshow or vm featured products css file and adjust the parameters,,,
AuthorPostsThis topic contains 39 replies, has 18 voices, and was last updated by Saguaros 14 years, 5 months ago.
