Viewing 15 posts - 1 through 15 (of 26 total)
  • jalp123 Friend
    #131699
    Hi all,
    Set up my virtuemart store on Mesolite. However the Product slider and VM featured products modules show up on every page, despite setting the module to only appear at Home.
    As a result all the pages look like the front page.
    Can you help?
    example:
    http://www.muslimstickers.us/msus
    jalp123 Friend
    #263567
    To add – i have searched this forum and found someone with a similar problem with an earlier VM integrated template. He resolved it by comparing it to a JA-News module problem which was identical –
    solution is here http://www.joomlart.com/forums/topic/fix-for-ja-news-showing-on-every-page/
    HOWEVER – he did not explain what he changed in index.php – Can someone help?
    jalp123 Friend
    #263804
    Any help on this???
    #263814
    Hi jalp123 !
    I have checked your site , all link to Virtuemart have Itemid is “1”, this is itemid of Home menu. so Features product and product slide always display in top content , to fix the problem you can do it following steps below :
    – Go to admin >> extensions >> modules manager >> select Featured Products module and mod_ja_vmproductslide module –> you must make sure that them only display on Home menu.
    – Go to menu change itemid for Virtuemart menu item.
    jalp123 Friend
    #263880
    <em>@hainn84 71550 wrote:</em><blockquote>Hi jalp123 !
    – Go to menu change itemid for Virtuemart menu item.</blockquote>
    Sorrry i dont understand this?
    jalp123 Friend
    #263884
    just to clarify – the module virtuemart is id 44.
    #264001
    Ok ! Have you solved the problem ?
    jalp123 Friend
    #264046
    no – i dont understand what you mean :Originally Posted by hainn84
    winmonaye Friend
    #264222
    I don’t think its nothing to do with menu. It’s the cart problem.
    <blockquote>I have checked your site , all link to Virtuemart have Itemid is “1”, this is itemid of Home menu.</blockquote>
    As you said, virtuemart shopping cart link is somehow linking to item=1
    Also tax colum appears in the wrong place, and even I disable the tax, the tax colum appears and says” tax $0″.
    Can you help? I don’t think it happens in the original VM. Thanx
    1. tax_virtue
    #264261
    Hi jalp123 !
    Can you please send via PM an admin account of your website so that I could look into the issue.
    jalp123 Friend
    #264312
    #264399
    HI jalp123 !
    I can’t login with the account which you sent for me . Please check again !
    jalp123 Friend
    #264402
    sorry – resent to pm
    #264423
    Hi jalp123 !
    please check , it is ok , now . I have assign features product module and vmproductslide module only display in Home menu .
    #264425
    your problem is missing Shop menu , you must create a menu link to virtuemart when link to categories of our products module will get itemid from shop menu.
    I have created a menu shop in Top menu , so it doesn’t display on frontent.
This topic contains 26 replies, has 6 voices, and was last updated by  Sherlock 16 years, 3 months ago.
