August 9, 2008 at 8:08 am #264667
If you have not sorted this out I have found a way around this in J1.5 – a tad fiddly but sorts out the problem
August 13, 2008 at 12:21 am #265152Thank you, Once I created “Virtue Mart” menu, the link now doesn’t point to item=1.
August 28, 2008 at 4:54 pm #267729<em>@hainn84 72328 wrote:</em><blockquote>your problem is missing Shop menu , you must create a menu link to virtuemart when link to categories of our products module will get itemid from shop menu.
I have created a menu shop in Top menu , so it doesn’t display on frontent.</blockquote>Hi hainn84, i’m having the same problem and i tried ur method but couldn’t fix it, could u plz go to my account and check it for me? thanks
i also have other problems, the ‘you are here’ doesn’t work also, and featured products doesn’t work right.Sherlock FriendSherlock
- 2478 times in 2162 posts
August 29, 2008 at 1:37 am #267764Hi topmanx !
it is ok now , featured product module and ja_vmproductslide module you have assigned fot them display in all page , you have reassigned for them only display in Home page.August 29, 2008 at 2:09 am #267769<em>@hainn84 76444 wrote:</em><blockquote>Hi topmanx !
it is ok now , featured product module and ja_vmproductslide module you have assigned fot them display in all page , you have reassigned for them only display in Home page.</blockquote>i see, thank you so much. i’m very appriciated. 😀
August 29, 2008 at 2:12 am #267772Hi topmanx ,
– you go to admin >> extensions >> module manager >> select ja_vmproductslide module
– At the bottom : you can see box to select page for display.jordank87 Friendjordank87
- September 2008
September 3, 2008 at 3:55 pm #268524I am also having the same problem
- September 2008
September 3, 2008 at 4:21 pm #268529I am also having the same problem yet i wasnt before
September 4, 2008 at 3:12 am #268633Hi jordank87 !
have you created a shop menu link to virtuemart component ? -
This topic contains 26 replies, has 6 voices, and was last updated by Sherlock 16 years, 3 months ago.
