peteralfred Friend
peteralfred
- January 2011
- 3 times in 1 posts
November 27, 2014 at 4:01 pm #203117Hi,
I use JA Decor with MijoShop. I encouter a problem when I’m on the product page. If I enter a value larger then 1 in the quantity field (i.e. 10) and press Add to Cart. The Cart gets updated with just 1 item instead of 10. See attachment.
I changed back to the default theme of Mijoshop and this solves the problem. I also looked at the Joomlart demo of JA Decor and this has my problem too.
Thanks is advance for your help!
Peter
peteralfred Friendpeteralfred
- January 2011
November 27, 2014 at 4:21 pm #556848In addition: when I test it with the demo product Canon EOS 5D. I can’t add this to the Cart at all.
When I test is wit a Mijoshop theme and go to the Canon EOS 5D, it gives me a reminder (in red) that the dropdown is a required selection. When I make the selection and press Add to Cart, it workes fine.
Again I fear it has something to do with JA Decor theme for Mijoshop….. Please help I purchased the Mijoshop to get this working
ThanksAdam M ModeratorAdam M
- May 2014
- 1271 times in 1235 posts
November 28, 2014 at 8:02 am #556910Hi,
Please provide your site url so I can have a look and investigate the problem for you.
- January 2011
November 28, 2014 at 10:57 am #556928Thank you adam. But I have it on a localhost. The problem I have is also present in the Joomlart demo of JA Decor. Can you investigate it from there?
Thanks advance.I’m looking at header.tpl and product.tpl but I can’t fix it…
hjalte1983 Friendhjalte1983
- September 2012
- 9 times in 1 posts
- May 2014
December 1, 2014 at 4:32 am #557117Please try the solution as suggested in this thread and let me know if it you still need further assistance.
1 user says Thank You to Adam M for this useful post
- January 2011
December 1, 2014 at 11:06 am #557192<em>@Adam M 455572 wrote:</em><blockquote>@peteralfred,
Please try the solution as suggested in this thread and let me know if it you still need further assistance.</blockquote>
Yes, this works. Unfortunately I had also figured this out myself, spending part of my weekend. But no problem. Thank you very much for helping!
I also updated the other thread (concerns the addition of the styling cart image).
And I understand this bug will be fixed in the next release, which is great. Thank you.
AuthorPostsViewing 7 posts - 1 through 7 (of 7 total)This topic contains 7 replies, has 3 voices, and was last updated by peteralfred 9 years, 12 months ago.
Mijoshop product page add to cart problem
