  • Kiên Trung Friend
    #189166
    I don’t know why, when i set 1 module position right1, 1 module position right2. But font end show not good, 2 module display on position right1.
    Kien
    1. kkk
    Kiên Trung Friend
    #499882
    Hi Support Joomlart,
    Pls support for me, it’s very urgent beacause the my project have to release for customer,
    Kien
    Ninja Lead Moderator
    #499892
    This is the screenshot of right1 and right2 postions on JA Teline IV Template
    You can try to clear cache from the Admin area (as well as disable cache in advanced option of these module) after apply any changes
    If you still face the same problem, you can pm me url of your site and admin access, I shall check it for you.
    1. position_right_1_2
    Kiên Trung Friend
    #500032
    <em>@Ninja Lead 381858 wrote:</em><blockquote>This is the screenshot of right1 and right2 postions on JA Teline IV Template
    If you still face the same problem, you can pm me url of your site and admin access, I shall check it for you.</blockquote>
    Tks, I fixed it’s Okie, there are bug very hard, we imposible fix when support want to access site to fix but many project development on localhost before publish internet. how to ?
    #500115
    You can explain us to step by step the problem you are still face and an illustrated screenshot of what you are trying to achieve, we will try to do that on your system, if we can duplicate it, we will send to you the solution to fix it 🙂
This topic contains 5 replies, has 2 voices, and was last updated by  Ninja Lead 11 years, 5 months ago.
