  • testcouch Friend
    #195864
    JA Top Panel module settings are not showed in Joomla 2.5.19
    1. JA-Toppanel
    Ninja Lead Moderator
    #527285
    I have upgraded JA Top Panel module from version 2.5.2 to version 2.5.5. Now, the problem on your site has gone. But I found another problem – the background image path from module could not access: templates/ja_social_t3/images/trans-topcpanel.png file. Please check that again.
    testcouch Friend
    #527347
    <em>@Ninja Lead 417068 wrote:</em><blockquote>I have upgraded JA Top Panel module from version 2.5.2 to version 2.5.5. Now, the problem on your site has gone. But I found another problem – the background image path from module could not access: templates/ja_social_t3/images/trans-topcpanel.png file. Please check that again.</blockquote>
    thanks for your new 2.5.5 version..
    i checked trans-topcpanel.png and it is is located in /modules/mod_jatoppanel/assets/images/ folder but not in templates/ja_social_t3/images/
    #527475
    <em>@testcouch 417142 wrote:</em><blockquote>thanks for your new 2.5.5 version..
    i checked trans-topcpanel.png and it is is located in /modules/mod_jatoppanel/assets/images/ folder but not in templates/ja_social_t3/images/</blockquote>
    Yeah, you are right, it was removed from template and you can use it for module or background color.
    testcouch Friend
    #528081
    <em>@Ninja Lead 417306 wrote:</em><blockquote>Yeah, you are right, it was removed from template and you can use it for module or background color.</blockquote>
    what do you mean with “it was removed from template and you can use it for module or background color?
    #528232
    I meant that in the new version, JA Top Panel module does not use the image “templates/ja_social_t3/images/trans-topcpanel.png” file from template, but you can use modules/mod_jatoppanel/assets/images/trans-topcpanel.png file from module or use background style from css file
This topic contains 6 replies, has 2 voices, and was last updated by  Ninja Lead 10 years, 9 months ago.
