January 18, 2018 at 11:36 am #1087525This reply has been marked as private.
January 19, 2018 at 2:47 am #1087614Hi,
It looks like you’ve customized layout of this template, I see that there are some new classes, divs: http://prntscr.com/i2h0es
You can compare with our demo site here: http://ja-teline-v.demo.joomlart.com/index.php/en/
Pls revert your changes first and see how it goes.
January 22, 2018 at 7:08 pm #1088094Hi, Thank you for get back to me. I have seen your print screen, but be honest I don’t really know, what is it, or where is it , as I never seen that page what you were print screening. I am not an expert, and honestly I do not know where or how I could done it. Could you please help me out, as we are not a professionals and doing non-profit work only. Thank you in advance
Norbert
11
January 24, 2018 at 5:03 pm #1088354This reply has been marked as private.Saguaros Moderator
January 25, 2018 at 6:54 am #1088435Hi,
It seems that you used the ‘magazine’ layout for the homepage, by default, it should use ‘magazine-home’ layout. I just changed it for you under Admin panel >> Extensions >> Templates >> JA Teline V – Magazine > Layout tab.
Kindly take a look.
January 25, 2018 at 8:45 am #1088452Thank you for your kind help, you guys are the best. One more question: if you are opening an article, you could see the same problem, where it shows the previous or next article just above the Typography. could it be related to the issue what you just sorted? Could you please have a look at that as well? Thank you again, much appreciate your kind help.
This topic contains 9 replies, has 2 voices, and was last updated by norbi741 6 years, 7 months ago.
The topic ‘Mobil view problems and slide show size problem’ is closed to new replies.
