amarks56 Friend
amarks56
- June 2011
- 3 times in 1 posts
September 29, 2013 at 6:22 am #191004The mobile layout (iphone) looks really bad on my site. I tried disabling it in template manager and it doesn’t work. How can I make it look just like the desktop layout? I just want all devices to view my site the same (desktop).
Thanks in advance.
amarks56 Friendamarks56
- June 2011
September 29, 2013 at 6:04 pm #507425I tried following another post and made a little progress, but now:
-everything is unaligned
-slideshow is cut off
-there is a T3 logo replacing my logo
-there is a “navigation” text ontop of my menuI would really appreciate help on fixing this, as this is the last issue I have before making my site live.
Thanks support team!
Saguaros ModeratorSaguaros
September 30, 2013 at 3:54 am #507450Hi amarks56,
Did you try to take a look at this thread: http://www.joomlart.com/forums/topic/deactivate-iphone-tablet-android-in-the-puresite-template/#post-507131
- June 2011
September 30, 2013 at 4:13 am #507454Thanks Saguaros! I will try it now and let you know!
- June 2011
September 30, 2013 at 4:19 am #507455I think I am making the problem worse :-/ … can you please help me?
September 30, 2013 at 8:08 am #507477Could you tell me more details of current problem?
- June 2011
September 30, 2013 at 5:18 pm #507571<em>@Saguaros 391683 wrote:</em><blockquote>Could you tell me more details of current problem?</blockquote>
Sure, thanks for helping me out on this one Saguaros.
Attached is a screenshot comparing the browser and mobile.
Problems:
-The slideshow gets cut off
-Many elements are pulled to the left, such as the Menu, “my 3d projects”, and the social media icons on the bottom.
-My logo doesn’t appear
-The word “navigation” appears above menu.Keep in mind that the root this site on FTP is the “Alex” folder.
I would really appreciate help on this, because I am doing many sites and I want to know how to make this work for all of them.
Thanks!
- June 2011
October 1, 2013 at 3:02 am #507597Hi Saguaros, let me know if that works. I just PMed you!
- June 2011
October 2, 2013 at 2:05 pm #507804Any help on this?
- June 2011
October 3, 2013 at 4:35 pm #507934Don’t need help on this anymore. Thanks.
October 4, 2013 at 2:19 am #507964Did you get it solved? 🙂
- June 2011
October 4, 2013 at 2:23 am #507966No I didn’t. I went on Odesk to get help. It’s just that it’s the last the I need done before making my site live and it’s keeping me up at night. The guy isn’t going to start until tomorrow, so you want to try to help fix that would be appreciated too. Also posting the solution to help others on here because there seems to be other with the same issue.
I PMed my info
- June 2011
October 4, 2013 at 2:26 am #507967your message box is full
AuthorPostsThis topic contains 21 replies, has 2 voices, and was last updated by amarks56 10 years, 11 months ago.
