Thanks Saguaros. I also changed the template width, since slideshow was bigger, along with some other css changes. Now my problem is that certain pages, on mobile devices, load fully zoomed out (which I want), while others load zoomed in.
For example:
–Home page loads zoomed in
–Portfolio, starts zoomed in for a second, then jerks outward to zoomed out view
–My Setup loads PERFECTLY
-Blog, About, and Contact, loads zoomed in as well.
How can I make it so that they all load zoomed out like the “My Setup” page?
Oh also, I had to change my passes. I just sent you the updated pass. Thanks!
Any help on this?
Was caused by some pages not having enough height.
Did you try to remove this code?
<meta name="viewport" content="width=device-width, initial-scale=1.0, maximum-scale=3.0, user-scalable=yes"/>
<meta name="HandheldFriendly" content="true" />
in templatesja_template_nameblockshead.php file
This topic contains 21 replies, has 2 voices, and was last updated by amarks56 10 years, 11 months ago.
