  • abdullah canipek Friend
    #1002797
    I dont use the off-canvas menu function, i enable Collapse navigation for small screens option.
    And use only one page exclude Scrolling Home Page called Blog, so home page is superb in the mobile view but when i open Blog Page then i can not return Home Page, i think this problem arises from itemId linking system.
    How can i fix this?
    Regards.
    Did you try to take a backup of your site and apply my suggestion here? https://www.joomlart.com/forums/topic/top-navigation-menu-problem-in-1-0-2-version/#post-970173
    #1003128
    Great ! Thanks a lot @saguaros.
    You’re welcome!!!
This topic contains 3 replies, has 2 voices, and was last updated by  Saguaros 7 years, 11 months ago.
