  • amolles Friend
    #154860
    Please can you help me..
    I’m trying to insert a link form my images sl-1, sl-2 etc… to others pages of my site.
    I’m following the help description parameters
    syntax:
    imagenmame:caption=image cation….. etc
    but it doesnt work
    my image name is”sl-1.jpg”
    my website page is “http://www.clicplace.com/index.php?option=com_content&view=article&id=88&Itemid=83” for exemple
    Thanks a lot
    Best regards.
    Alain
    i have checked this issue, the link did not work right as we configured. i have created issue on the PM at http://pm.joomlart.com/browse/JATCZEOLITEII-70, our developer will check and fix this issue, please give us some time to do this task
    antrumble Friend
    #358631
    Hi Tien,
    Did this problem end up getting fixed? I’m having a problem getting links to work as well.
    Kind regards,
    Anthony
    <em>@antrumble 198070 wrote:</em><blockquote>Hi Tien,
    Kind regards,
    Anthony</blockquote>
    Dear Anthony!
    Im sorry this issue is not fixed, You can switch to use the ja slideshow2 module, which supported well making link to each image of item
This topic contains 4 replies, has 3 voices, and was last updated by  Saguaros 14 years, 2 months ago.
