  • baladic Friend
    #146843
    Hi!
    I use the Ja Teline II template in joomla 1.5.15, and i have a problem with the mod_ja_slwi Spotlight Module. When the text is utf-8 (Greek), there is the “invalid character” <?> at the end of it (on hover in frond-end).
    i tried to change all the files of module in utf-8, but nothing happens. My site is on localhost at the moment.
    Any solutions?
    ekfrasi Friend
    #514234
    I have the same problem on a server installation.
    Hi ekfrasi,
    You should also check the collation of database in your site, make sure that it’s utf8_general_ci
This topic contains 3 replies, has 3 voices, and was last updated by  Saguaros 10 years, 11 months ago.
