  • vimoozco Friend
    #186015
    I am using Viruemart 2.0.2 and Joomla 2.5.6. I am trying to use mod_virtuemart_products module on the homepage in User5 position but it is displaying the items vertical instead of horizontal. It only works when I select [x] show product price and [x] Show Add-To-Cart Link? but then it appears to conflict with other extensions and they do not work. I will like to display mod_virtuemart_products module on the homepage in User5 horizontal with no product price and no showing addd-to-cart link.
    Hi vimoozco,
    It seems to be a bug from this mod_virtuemart_products of Virtuemart. You can raise an issue to Virtuemart forum for further help. Here is my suggestion.
    Suppose that you configure this module like this:
    Then you open file: /templates/ja_orisite/css/template.css, add this css rule:
    .width50.floatleft {
    float: left;
    width: 50%;
    Then try cleaning the cache.
    Hope it helps.
    vimoozco Friend
    #487838
    It still does not work. I saw this on the virtuemart website re: something about template override
    http://forum.virtuemart.net/index.php?topic=108765.0
    Is there possibly a conflict with the theme. I am using VM 2.0.20a and Joomla! 2.5.9
    Hi vimoozco,
    You can switch default template – JA Orisite- to another standard joomla template so that we can know the problem comes from VM or our template specific. If problem still persists, there must be problem with VM itself.
This topic contains 4 replies, has 2 voices, and was last updated by  Saguaros 11 years, 9 months ago.
