  • kamine Friend
    #170043
    Hello i am using the JA T3 template to built a site
    I have two link that display in modal box a contact form and google map in normale case the modale box should display on ly google map or contact form but it dispaly all site frontend with module and menu i have this issue just with JA T3 template in JA purity it work fine
    I read in some topic trought google i found this solution
    fix error :
    pluginssystemjat3corejoomlapagination.php
    find line 27 to replace :
    27 class JPagination extends JObject
    by :
    if (class_exists(‘JPagination’)) {
    and this at end of file:
    But i still have the problem
    and to explane more this is screenshot of my local web site
    this should display only the google map
    Many thanks
    1. Untitled-1
    khoand Friend
    #421538
    We need to view your website directly to find down what happened. When you publish your website, you inform us. We will help you.
    kamine Friend
    #421549
    Hello i solve that with replacing compenent.php in JA T3 template the same file in JA Putity template
    Many thanks
This topic contains 3 replies, has 2 voices, and was last updated by  kamine 13 years, 2 months ago.
