  • davida Friend
    #126272
    I’ve been trying to install the rsgallery2 in every possible way and I keep getting errors.
    I had it with Joomla 1.0.15 and now with 1.5 too.
    I installed the quickstart for 1.5 and although rsgallery is in the components folder, it doesn’t show up in my components. So I tried to install the zip package and I got an error saying no valid xml. I unzipped it and tried to install it as a directory and I get
    “Fatal error: Allowed memory size of 8388608 bytes exhausted (tried to allocate 40961 bytes) in C:wampwwwja_avian_ii_quickstart_for_15RC4librariesjoomlaapplicationmodulehelper.php on line 155”
    Can you please post the solution or let me know why I don’t have the gallery installed already if I work off of the quickstart. I’ve spent much too long trying different options.
    Thanks!
    #241228
    Rs gallery only have version for Joomla 1.0, if you want to install it with Joomla 1.5, first you must publish legacy plugin in Plugin Manager.
    #241429
    You can read Sticky :Fix for timeout issue while installing RSGallery2 component! on the top of this forum. It have tutorial to fix your bug
This topic contains 3 replies, has 2 voices, and was last updated by  Sherlock 16 years, 9 months ago.
