August 28, 2012 at 10:42 pm #180321
Hi. My site is http://www.ymca.oneofakind.ws. I too am having the module alignment issue. I’ve looked on the forum, but I haven’t found a way to fix it. Please let me know what to do.
Thanks!
HeR0 FriendHeR0
- August 2011
- 588 times in 549 posts
August 29, 2012 at 7:36 am #465706Hi Jeremiahbenes,
In articles or modules which displays on homepage is missing div closed tag. Please check them.
Regards,
August 29, 2012 at 11:11 am #465741i got some problem too here is my thread : http://www.joomlart.com/forums/topic/module-right-ja-portfolio-2-5-mess-up/ :((
August 29, 2012 at 12:34 pm #465751<em>@HeR0 336399 wrote:</em><blockquote>Hi Jeremiahbenes,
Regards,</blockquote>
Thanks for your help. I have checked all my articles and I couldn’t find any that contain a missing div tag. Any other ideas?
<em>@swype 336441 wrote:</em><blockquote>i got some problem too here is my thread : http://www.joomlart.com/forums/topic/module-right-ja-portfolio-2-5-mess-up/ :((</blockquote>
I’ve been watching your thread. Hopefully someone will post a solution publicly for this.
- November 2014
- 3854 times in 3563 posts
August 31, 2012 at 2:08 am #465878@jeremiahbenes: I have applied to fix the error on your site. Please check it again.
This is bug override on our template. I will apply this fix to our product and release it on next version JA Portfolio Template.
August 31, 2012 at 4:01 am #465893Thanks so much for all your help!
- November 2014
August 31, 2012 at 4:37 am #465900This is my solution
Copy
components/com_content/views/featured/tmpl/default_item.php
Paste override to
templates/ja_portfolio/html/com_content/featured/default_item.php
Or you can compare with default_item.php file is missing “div” on template with component
3 users say Thank You to Ninja Lead for this useful post
October 24, 2012 at 2:35 pm #471006Could you explain exactly what code is to be copied and where it should be pasted?
Working localhost.
- November 2014
November 2, 2012 at 4:23 pm #471793Yes !!! Thanks A LOT !
I was going crazy with that module position for days…
It’s at last solved with your attached file.
Well thank you again.jeronimov Friendjeronimov
- October 2012
- 1 times in 2 posts
November 2, 2012 at 4:48 pm #471794On a J25 install, either uploading this file or getting it from my own components/com_content/views/featured/tmpl/default_item.php
fixes the module position alignment problem but breaks the style of my featured articles in the Home page. Any ideas on how to solve the alignment without messing up the featured articles? see http://www.ceramicasantiago.comjeronimov Friendjeronimov
- October 2012
November 2, 2012 at 5:17 pm #471797The final explanation came from Chavan in the post:
http://www.joomlart.com/forums/topic/right-module-alignment-off/<blockquote>I have fixed the issue:
Issue was this file: /templates/ja_portfolio/html/com_content/featured/default_item.php
The article-tools End DIV tag was closed after the EndIf statement, I have moved it before the Endif statement
This is the fix.</blockquote> -
This topic contains 12 replies, has 7 voices, and was last updated by jeronimov 12 years, 1 month ago.
