  • john_kappas Friend
    #1092339
    I want to change the background color of a module.
    On the advanced tab on the Module Class Suffix I type _blue but it doesn’t work (same with _red or _black).
    I tried with module style xhtml but still not working.
    My module position is footer 1. I also changed the position to Position 1 but still the same.
    Can you please help me? Do I miss something?
    Pankaj Sharma Moderator
    #1092461
    Did you add the module classes in the CSS files like custom.css file?
    Please share the URL of page as well.
    john_kappas Friend
    #1092492
    Goodmorning,
    I thought that these styles were included at the template.css and it wasn’t necessary to create my own custom.css file.
    My web pages is http://www.taxitripolis.gr but I still haven’t finished the transformation and it is closed for the public.
    I will solve my problem by using background colors of bootstrap (<div class="col-xs-6 col-sm-3" style="background-color:gold;"> )
    Regards,
    John Kappas
    #1092493
    You need to define the suffix in css file and add it in the module .
    This documentation helps you.
    https://docs.joomla.org/Module_Class_Suffix
This topic contains 3 replies, has 2 voices, and was last updated by  Pankaj Sharma 6 years, 10 months ago.
