  • globogsm Friend
    #131189
    I am using Joomla 1.0.15 and Virtuemart 1.1.0, I inserted a template position under the mainbody:
    <?php mosLoadModules('vetrina', -2); ?>
    where I inserted the module mod_virtuemart_randomprod.
    All good, but let me give a graphic style to module, exploiting the parameters Module Class Suffix , but whatever I enter, nothing changes …:((
    how can I solve?
    thank you 😉
    Menalto Friend
    #261556
    [PHP]<?php mosLoadModules(‘vetrina’, -3); ?>[/PHP]
    Try to change to the above. Does that help?
    #261645
    I think i must make css for that module class suffix
    #262368
    Hi globogsm !
    Have you solved the problem ?
    Menalto Friend
    #270471
    Did you manage to solve this? if so please mark this as solved, if not and you still need help please post here again and include your joomla version, template verison and a description of your problem if different from before.
This topic contains 5 replies, has 3 voices, and was last updated by  Menalto 16 years, 3 months ago.
