bins Friend
bins
- March 2011
December 15, 2011 at 11:25 am #171832I am trying to have different colour title boxes, but can only get blue to work!
Although I put ‘blacktitle’ in the module class suffix box in the module page, but nothing happens. I have tried different variations for the title and main box and cannot get a result!
BTW, blue & green appear to be the same colour!
pavit Moderatorpavit
December 15, 2011 at 11:32 am #429731Hi bins
May i have via PM your login details ?
If i can check the configuration directly to your backend it’s better
December 15, 2011 at 2:30 pm #429741Hi bins
I have checked on your site and all works fine your theme override works fine the green and the blue theme are different if you check better
try to apply the profile to different pages in the main menu and you will notice the diffrerence
for the module class suffix as you can see in your home page i have published 2 custom-html module with 2 class suffix blacktitle and bluetitle and both are perfectly functioning as expected.
When you insert the suffix you must leave the first space empty, look at that 2 modules
bins Friendbins
- March 2011
December 15, 2011 at 2:58 pm #429746The suffix space – that was my problem!
Thanks for sorting that out.
BTW, I have edited the test modules, one to be green and one to be blue and they are both the same colour!
bins Friendbins
- March 2011
December 15, 2011 at 3:06 pm #429749Pavit, scrub my last comment – it looks like green and blue are the wrong way around.
Also, I have noticed if you enter info incorrectly, the box defaults to red!
This topic contains 7 replies, has 2 voices, and was last updated by bins 12 years, 11 months ago.
