June 21, 2010 at 7:29 pm #151947
I have some modules in the right column.
No problem adding module class suffix to them; they look as they should.
But i can’t control the two modules i have in the left column (user menu & log in).
They do not behave in the same way..See screenshot to know what i mean.
How can i make the left column modules the same as the right column modules?-
micrantha Friend
micrantha
- May 2007
- 158 times in 148 posts
June 21, 2010 at 8:11 pm #347636Hello,
What layout do you use for your site?
In template parameters you can configure layout: if you use left-main-right.round, you will have rounded module style in left and right column.Good luck,
MicranthaJune 21, 2010 at 8:29 pm #347642Hi, well, if you had looked at the screenshot…. you would have seen that i have configured this layout….
micrantha Friendmicrantha
- May 2007
June 21, 2010 at 8:54 pm #347644Hello aprox,
I did take a look at your screenshots but left column has no rounded modules. So: it looks like you do not use layout left-main-right.round. You use this layout but rounded corners do not show up? Or am I missing your point?
regards,
MicranthaJune 21, 2010 at 9:01 pm #347645{SOLVED} turned out to be a typo
June 22, 2010 at 12:03 am #347653Sorry, What is the problems_
Viewing 6 posts - 1 through 6 (of 6 total)This topic contains 6 replies, has 3 voices, and was last updated by capacitadoresdeti 14 years, 6 months ago.
