alpinevp Friend
alpinevp
- April 2009
- 2 times in 1 posts
November 8, 2010 at 3:49 pm #156189There seems to be a laziness on the part of the developers with regard to providing a complete list of all module class suffix variations for this and all other templates. The only variations that are published are just those used in the demo and the User Guide. Does this mean that these are the ONLY module class suffix variations available? Where is the master module position diagram (see attached example that indicates all possible module positions)? It seems that for all of the great effort put forth in these designs, we are intentionally being limited in access to the knowledge needed to fully utilize the template.
aman204 Friendaman204
- January 2010
- 418 times in 356 posts
November 9, 2010 at 12:29 pm #362101Please view the links below as they would redirect you to varied module suffixes and easy way to make optimized use of ?tp=1 to know the positioning of template::
1) Module suffixes
http://www.joomlart.com/forums/topic/module-class-suffix-styles-basic-to-enhance-your-modules-2/#post-3607852) Module positioning locater::
http://www.joomlart.com/blog/jat3-framework/jat3-feature-spotlight-joomla-module-positions-tp=1-now-much-betteralpinevp Friendalpinevp
- April 2009
November 9, 2010 at 2:44 pm #362110Aman,
You are completely missing the point. You clearly know what I am referring to as your own website is using RT’s Logic and anyone that uses RT, YOO, JoomlaBamboo, et al, knows that every one of those theme developers provide a page with the examples of all of the built in module suffix class stylings and a page that has an all module position diagram. What I fail to understand is why it is so difficult for Joomlart to, at the very least, provide the module suffix class examples for each template that is already built into it. I get that the JAT3 allows for you to add additional css and module classes but not everyone is as talented as you are.In Community Plus, there are already module suffixes built into the template. I wish to know what all of these variations are and it is not unreasonalbe or too much to ask that Joomlart take an extra 10 minutes and create that expample page, especially for the developers license. So again I ask the very simple question…Where can I go to see what all of the inbuilt module class suffixes are for Community Plus???
- January 2010
November 9, 2010 at 4:49 pm #362123You can even use in some pre-built suffixes in this template
_menu , _blank, _noborder
Also, Please note that the suggestions to create new suffixes for the template in tutorial links is easy one and can have in-built feature for the template with suffix you apply 🙂
If you wish, I can even explain the tutorial implementation for suffixes in more depth
Cheers
- April 2009
November 9, 2010 at 5:02 pm #362125Aman,
I am not trying to be rude or beligerent but you did not answer my question at all. I am not interested in adding new suffixes, I want to know what is already built into the template, what are they and what do they look like?So again I ask the very simple question, again…Where can I go to see what all of the inbuilt module class suffixes are for Community Plus???
See the attached from the RT Kinetic template that you are using on your softlogique.com website. Unless you are Ray Charles, you can clearly see the built in module class suffix styling for this template.
- January 2010
November 9, 2010 at 5:09 pm #362127Firstly, I would please suggest you to be bit polite while asking in forum area as this comment ::
<blockquote>
Unless you are Ray Charles, you can clearly see the built in module class suffix styling for this template.</blockquote>doesnt sound too good.
<blockquote>So again I ask the very simple question, again…Where can I go to see what all of the inbuilt module class suffixes are for Community Plus???</blockquote>
This has been discussed earlier with our team to have it in template so I would even suggest you to post this in here also ::
http://www.joomlart.com/forums/forum/request-and-wishlist/alpinevp Friendalpinevp
- April 2009
November 9, 2010 at 5:33 pm #362131I prefaced the comment with a stated up front apology for stating the obvious <blockquote>”I am not trying to be rude or belligerent…”</blockquote> but clearly I am frustrated with the lack of a response to the original question. I truly believe you understand my question but it is confusing that you cannot provide me with a direct response.
Based on your last comment, it would seem that there is no way to provide an answer. Is this correct?
- 2008 times in 1700 posts
November 11, 2010 at 2:08 am #362369Hi alpinevp,
We do acknowledge that we still have tons of works to improve the documentation & make it at the same page as our products’ features. Specific plans are being realized for better userguide, video tutorials which hopefully come out soon for all’s conveniences.
For now, pls check again the JA community plus userguide as it has been updated, clearly define what includes/not include module class suffixes & link to full module position
AuthorPostsViewing 8 posts - 1 through 8 (of 8 total)This topic contains 8 replies, has 3 voices, and was last updated by Anonymous 14 years, 2 months ago.
