  • michauda Friend
    #136905
    Please see the attached image to see what I mean.
    I’m using JA Sanidine II.
    In IE7 (this doesn’t happen in FireFox) the left edge of the modules disappears and you get what you see in the image.
    I’ve had this happen with modules in the left position as well.
    I have never seen this happen in the demo on joomlart, but it’s happened for every install I’ve done on my local server.
    Any ideas? :confused:
    Thanks!
    1. problem1
    #285543
    Hi michauda !
    it is strange problem , i have checked on my local and some other computer but can’t see the problem , i think this is a problem with IE7 on your computer, please try to check on other computer.
    jordwbush Friend
    #285959
    This problem is with IE6. I also see this problem but can’t fix it now.
    Anybody can help?
    #286039
    Dear jordwbush !
    I still have checked it in IE6 but can’t see the problem , please kindly send live url , i want to check it.
    jordwbush Friend
    #286229
    I think it’s happening when using with all 3rd party modules except JA Sanidine & JA Sanidine II ,
    It may solve by adjust the width of something (css or ), but I don’t know where to fix this.
    Thank you..
    1. raanaroii
    michauda Friend
    #286317
    jordwbush is right.
    To fix any modules with this issue you’ll have to edit the HTML of the module as shown below.
    <table width="100%" border=0"><tr><td>
    Module HTML Here
    </td></tr></table>
    This solved the issue for all of my modules!
    Hope this helps!
This topic contains 6 replies, has 3 voices, and was last updated by  michauda 15 years, 11 months ago.
