  • lgbtnation Friend
    #129325
    I have tried everything to get this template working. Modules, Ja News, etc , I can not get the Ja News section on the home page to work. All the suggestions are not helping. I’m having some issue with the Column spacing and when I enable the Ja news, the white space moves and shifts all my images, etc, right in the middle of the page!!!? I know 1.5 is a bit new, but I have used several templates over 2.5 years, so I’m done this before… Is there something in the coding that I’m missing?
    Remember Ja News I’ve done, every part of the directions. I’m created Modules, I’m set up categories… I can’t figure this out… please, please emails me adrienne@tallexpression.com this should have been up weeks ago!
    Thanks.
    http://www.tallexpression.com
    Menalto Friend
    #252074
    Error
    * Username and password do not match or you do not have an account yet.
    lgbtnation Friend
    #252075
    thanks… it seems I have to create modules for every home page…..I get it now! but not sure how to make it the same side. I will remove the offliceline so you can take a look…. thanks… any help you can give me!
    lgbtnation Friend
    #252077
    no this isn’t have a front-end templete should be, I know something isn’t right.
This topic contains 4 replies, has 2 voices, and was last updated by  lgbtnation 16 years, 7 months ago.
